Smart by Bond v2.10.12-beta Firmware
We have a BETA version of the firmware for SBB Fans now available via the Bond Home BETA iOS app.
We intend to ship this next week (Jan 2nd) and it has low associated risk, but I wanted to give you all a chance to review the changes and try the new features before it becomes generally available.
The latest app version is v2.17.1-beta. For iOS, you can get the latest beta using this link: https://testflight.apple.com/join/75fqJf9U
Happy Holidays!
v2.10.12-beta
This applies only to Smart by Bond units with serial starting with:
  • KS
  • KN
Changes since v2.10.10
(See Master release notes for v2.10.10)
New Features
(none)
Bug Fixes
  • Implement a workaround for some fans (serial numbers starting in KS) that turned on by themselves after v2.9 update (#737)
API
(none)
v2.10.10
  • KC
  • KV
All other Smart by Bond units do not yet have this update available. That release is planned sometime in Q1 2020.
Date : Thu Dec 5 10:36:31 EST 2019
Changes since v2.9
New Features
  • Support for Smart by Bond ceiling fans with Up Lights
Bug Fixes
  • Fix a light glitch when restoring power introduced in v2.6.40 (#635)
API
  • fix SetDownLightBrightness causing UpLight to turn on (#639)
  • BPUP: Bond Push over UDP (#650)
  • /sys/reset: fix spurious 500 error (#671)
  • /token: Allow disabling token authentication; still enabled by default (#661)
  • /devices/1/properties.feature_xxx: Feature Toggles for Light, Brightness, UpDownLight (#710)
