Hi,
After configuring the Bond Bridge Pro I disabled internet access to it (only ever wanted local connectivity).
Shortly after it started broadcasting an open wifi hotspot, basically allowing anyone nearby to come in, browse the Bond bridge connection and potentially hook it into their own wifi network instead.
Is there any way I can manually disable either the open wifi hotspot? It is has network plug anyway so there is no reason to use wifi full stop.
Cheers
