Nice Red: older ERGO1/Domì awning needs “hold 5s / 3× / confirm” enrol (PROG jog not available)
Hi Bond team,
Goal: Pair Bond Bridge as a Nice transmitter for a ~20y EU patio awning (Nice Red / O-Code).
Remotes: ERGO1 (original) + Domì P1 (mono/O-Code, cloned from ERGO1). Both control the awning fine.
Blocker: App Nice Red flow expects PROG → motor jog. On this install PROG never triggers learn mode (Domì PRG = no reaction; ERGO1 has no usable PROG path; motor P1 not accessible). Rolling-code “Other/learn” is not a workaround.
Working Nice enrol on this motor (how Domì was added). Use one button for the whole sequence — UP, STOP, or DOWN:
  1. Next to motor
  2. New TX: hold button 5–8 s → confirm (beep/flash/jog)
  3. Paired TX: same button ×3 (~1 s on / ~1 s off)
  4. New TX: hold same button again → final confirm
Ask: Add/document a Nice Red enrol path where Bond is the new TX in that sequence (prompt button → hold → user does ×3 on old remote → Bond confirm hold), as alternative to PROG-jog.
Happy to share Bond ID / FW / remote photos. Thanks.
