If you don’t have a legacy Works with Nest IFTTT plugin available on your account, I don’t believe you can add it any longer.
Also, as far as I know the IFTTT support for Bond has been sunset; integration options would lean towards a hub-based or API / URL call integration.
You can also look at the SmartThings -> IFTTT path?
