Just purchased a Minka Aire Deco Fan with Dimmable Light Kit and having a few issues.  Any help would be appreciated.
FCC ID: 2ABUP-FT0310MK
- The remote is not found in the app, only manual recording is available. How often does Bond add remotes?
 - Cannot control dimmer (known issue listed on website).
 - Bond cannot reliably turn the light on and off. I believe this is due to how the Bond sends its signal to the fan as a long press. Since the light toggle button controls the dimmer if you press and hold. So the fan is usually receiving the long signal sent as a dim command instead of a toggle command. I’m working through the API information now to see if I can figure this out but I thought I remembered some kind of time delay that was configured when I first set up the app but can’t seem to find it right now.
