I have a Casablanca fan with a battery operated wall remote see photo) and hand held remote.
I can program the fan speeds but am unable to have my light turn on and off.
Did you attempt to program the Bond Bridge via your handheld remote, or the wall control / remote?
When you went through setup, did it give you an option (after testing one or two buttons) to use a template?
(If you don’t remember, if you go under the device in the Bond app, go to Settings on that device and expand the Advanced section, it’ll say Template right above Local Token, if indeed it had a Template; if it does, which template is it?)
As an aside: that remote reminds me of one I had in a previous house; does tapping the up or down on the light turn on and off, and holding dims it? I think the handheld remote has a power button on the side for the fan on/off? I was able to get the fan and light to all work but can’t remember if I had to try to learn the device multiple times until I got it just right.
I think residual is onto something… Try just a very brief tap when trying to program the light.
Just came on this site in search for info on the compatibility of the Casablanca remote control 99020 with my bond bridge.
Hi Merck,
I have the same remote control as aaronac8’s. The FCC ID is IN2TX31.
Before I placed the order for the device, I check compitibility with the FCC ID. And I was told it’s supported by the Bond Bridge. However, when I was trying to set it up, it’s not that straightforward.
The only buttons the bridge can learn are those number buttons, which sets the fan to different speed. The other buttons cannot be learnt or even detected by the bridge. (Lights of the bridge would not turn green.)
But I did notice that after the brdge learn the signal for the number button, there is one option to choose templates. Like what Joachim47 mentioned, the template C2 works. I also tried tried the tempates for other FCC ID, they did not work as good as the C2 one. However, with the C2 template, the buttons are limited to those buttons showing in Joachim47’s screenshot.
Would it be possible to create a new template based on FCC ID IN2TX31?
Thanks,
Bob Gu
