iOS widget on Today screen not showing bond
Just purchased the bond bridge and noticed I can’t add it as a widget on the Today screen. Did this get removed? All my devices are allowed through the slider.
Thanks.
Hi @jkeen76
I’m one of the iOS developers and will try to help you.
Can you tell me what you see when you go to the app’s Today Widget screen? It is under the Settings tab.
This screen shows you which devices have available commands to be used on the widget.
Also, it is good to mention that we don’t have/support the new iOS Widgets (the ones that you can add to your “home pages”) because it can’t trigger an action “in background”.
So adding it to the Today screen you need to tap Edit in the bottom of the screen and then tap in Customize, also in the bottom of the screen. There you should be able to add the Bond widget to the Today screen :slight_smile:
Let me know if I can help you better with this!
