Heat-n-Glo Fireplace remote
AI Overview from Gemini 3.5 Flash
You can integrate your Heat N Glo On/Off Fireplace Remote Control (RC-BATT-FHH) with a Bond Bridge or Bond Pro by using the original radio frequency (RF) handheld transmitter to teach the Bond app the ON and OFF commands. [1, 2, 3]
How to Set It Up
  • Put fresh batteries in your RC-BATT-FHH remote so it transmits a strong signal.
  • Open the Bond app on your phone and choose to add a new device, selecting Fireplace.
  • Select the RF option, since the RC-BATT-FHH uses standard battery-operated radio frequencies rather than infrared.
  • Follow the app prompts to press the ON button on your physical remote when Bond enters recording mode.
  • Repeat the process for the OFF button.
  • Test the commands through the app; if it doesn’t trigger the fireplace right away, community members on the Bond Home Forum recommend removing the batteries from your original handheld remote after recording so it stops interfering with the rolling or duplicate RF code transmission. [1, 2, 3]
