I have one fan bulb that consistently gets out of sync but amazingly doesn’t ever get back in sync. Is it possible to do a Fix State from Hubitat or SmartThings without having to go into the Bond Home app? Hubitat is the preference.
I think the problem is just a continuation of a previous post where I was finding interference between the Pico’s transmitting of a button push and the Bond hub sending the command to the fan. I swapped the Pico for a Eria Dimmer and haven’t had the problem since. However, I am still curious if there is a way to fix the state using Hubitat without having to open the Bond app. For example, flip a virtual switch that changes the state of the fan without actually sending a command to turn fan off/on.
