Emulating remote controls
Hi Guys,
I installed a luvelered roof gazebo un my backyard that works with a Dooya control. I installed the control into my Bond Bridge Pro and it works only when the hub is outside the house and close to the gazebo. When the Bond Bridge Pro is at my home data room it doesn’t reach the gazebo, so I can’t operate it trough the Bond App. Is there any way I can repeat the sign accross my house to reach the gazebo without moving the bridge from where it is?, I mean like a 433Hz bridge or repeater that can extend the sign, or any one have any experience on this issue? thanks folks for teh help!
Suggestion!
Once you checked out where in your house the bond bridge can still effectively control the gazebo roof buy a 2nd bond bridge (q: is a model pro actually needed?) and you have the problem solved and may even benefit from better signal distribution across your property.
Thank you, I need to find where and how to hide the additional bridge.
