Hi! I have the Bond Pro bridge (BD-1750-PRO) and it’s on the latest firmware (4.5.17-beta.) It is configured to control 7 shades and 1 set of drapes in my house and it’s been working well for a long while now.
I also have 4 AppleTVs around the house, 3 are wired and one is wireless. I updated one of the AppleTVs to the Developer Beta of tvOS 18 this week to test another app I’m working with. Everything else is working fine, however, when that AppleTV, with the latest OS, takes priority as the primary HomeKit hub, I see that I lose the ability to control the shades and drapes that are linked to the Bond Pro bridge.
I have tried turning HomeKit off and on again, in the Bond app, to no avail. I have not tried removing the Bond Pro bridge from HomeKit and adding it back because I was skeptical it would help and I didn’t want to lose my settings, room assignments, schedules, automatons, etc. associated with my drapes and blinds.
The only way I can regain HomeKit control of the drapes and shades now is by unplugging that AppleTV, so one of the other three AppleTV’s (still on tvOS 17.5.1) can handle the HomeKit hub responsibility. At that point, control of the shades and drapes return to the Home app. Once I plug that first AppleTV back in though, Bond control is lost once again. This is 100% reproducible. Prior to this tvOS 18 update, if didn’t matter which wired AppleTV was prioritized as the primary HomeKit hub, everything worked regardless. Now, this appears to be an issue that exists with tvOS 18 specifically, which will be releasing widely in a few months.
I have many other smarthome devices and many other bridges from many other manufacturers, and none of them are having any issues, for what it’s worth. It’s just the Bond bridge and it’s just when that one AppleTV running tvOS 18 beta is powered on and prioritized as the primary hub, that HomeKit loses control of Bond-connected drapes and shades… Which happens whenever it is plugged in, because it’s software is “the latest.”
I also know that tvOS 18 introduces a way for the use to choose a preferred HomeKit Hub: You Can Select a Preferred Home Hub in iOS 18 - MacRumors
However the only way to enable that setting is to first update all the AppleTV’s to tvOS 18. And in light of the issue reported above, I am loathe to update any of the others now, at least not until much later in the public beta cycle or after actual public release.
All of this to say, this is a heads up, that I believe the HomeKit compatibility of the Bond Pro bridge with the latest beta firmware, is having a serious issue with the Developer Beta of tvOS 18. I’m leaving that AppleTV unplugged for now but is there anything else I can do to troubleshoot, or is there more information I can provide so Bond is able to prepare ahead of time and get this fixed for when tvOS 18 is publicly released? If not hopefully this advance notice helps the development regardless.
I’m obviously happy to volunteer as a beta or even alpha tester for any updates you provide. Thanks!
