Is there a preferred/best position/orientation to mount the Bond Bridge Pro? High or Low? On the ceiling or wall? Horizontal or vertical?
Thx
Good question. If it’s a 2-story home under 3500 sq.ft., anywhere in the middle of the upper story should be fine as long as it is not right next to metal that may shield the RF signal.
Single story home. So, orientation or height has no effect? The RF signal goes out the same in every direction?
Basically, yes. Technically the antenna pattern is a function of frequency, but overall the Bridge seems to have a pretty isotropic pattern.
Thank you very much!
