My bond bridge controls some devices inside my house. However, it was not able to connect to my wall fan inside my garage. It can controls the fan only if I bring it physical inside the house and place it within a few feet from the bond bridge device. Once I take inside the garage, Bond bridge stops communication with the fan.
Unless you indead try to use IR communication, there is no way other than buying a 2nd Bond bridge placed in the garage.
Otherwise, with RF 400+MHz communication you may try to find for the Bond bridge a more proximate location which satisfies all devices you want to control by a single bridge.
Thanks for your response. May be buying a second Bond Bridge will solve the problem especially if Bond Bridge company is going update the system, we hope, to control garage doorl as well!
