I’m new to Bond and use the BD-1000 for my Somfy blinds - works perfectly.
Is there any chance the ATA PTX5 433 MHz remote will be added as an integration?
Thanks
Dave
Looks like a garage door opener remote? It may “just work” in manual recording, but if it has a rolling code then it will not.
It’s for my gates. It acknowledges when programming but doesn’t work and I suspect it does have rolling code. I believe Somfy has rolling codes too so it must be possible.
I’ve read elsewhere Bond has said there are too many options to support with rolling code. Would be good if there was a way the community could contribute like with some of the smart home communities.
