@smckdwn989 With the new 2.9.0 iOS app and v2.6.32 firmware, I was able to successfully integrate a Minka Aire fan into SmartThings using webcore. I started simple, created a virtual switch and then created a piston to respond to that switch turning on or off. Here is what the piston looks like:
I masked my token, IP address, and device-ID for obvious reasons. This piston works perfectly and the latency is dramatically lower than the silly IFTTT way of integrating Bond with SmartThings.
curl -i http://192.xxx.x.xx/v2/devices -X GET -d '{"_token": "xxx"}'
If you look closely, youâll see the difference. This forum often prints quotes in a way that is rejected by curl, it can be annoying but I havenât found a way to disable it. Typing inside a code block can prevent this.
thanks to the both you of, i was able to resolve the issue, it was the windows issue. I didnât know i needed /'s. So i was able to successfully integrate into webcore for my first living room fan. Itâs definitely a nicer solution than ifttt as itâs much quicker to respond. I tried adding another fan remote to the equation, the app works but when I integrate to webcore it doesnât respond. I know I have the device ID right as I tested it within the console. Iâm at a loss as to why this isnât working.
got it all fixed, was an issue with the piston switch names as well. so now I have 3 fans running hunter universal remotes, all working with GE switches. Single button turns the lights on, and double tap up/down turns on and off the fans. Itâs a simple nice solution and the latency is much better than ifttt
