Add select blinds shades without remote
I bought a select blinds “premier light filtering dual shade” roller shades and have misplaced my remote. While searching options online, I came across bond bridge and I got the non-pro version.
While trying to setup the shades (scanned the barcode from Select Blinds order page), I see that “Select Blinds” is not an option in the list of Shades that show up by default during the setup.
When I go via “Other” option in Shades, it asks for recording commands using the remote.
I then chose Advanced setup but there is no clear direction on what frequency I need to set for my device. Need some help here to proceed with setup. Or, is it mandatory to have the remote and go via command recording.
Hi Shashirs,
Do you have access to the 6-digit Select Blinds code from your order?
With this code, we’ll be able to guide you more effectively toward a solution.
Hi Nazareno, The code is 140276
Nice!
This code refers to the SmartView shades.
You just need to select this option in the app and follow the instructions to pair directly using the motor button — no remote control needed.
If you still need help, feel free to chat in real time with our support team directly through the app, ok?
You can count on us!
Thanks a lot @nazareno I was using Bofu type for this shade (got it to work by trial and error).
SmartView shades is right one to use.
