Watchdog api endpoint and running locally
Thank you for the detailed instructions. Appreciated.
I see that @y8yPE6AM reports making this change, but that “the blue light is still there.” By this I presume @y8yPE6AM means the blue light on the Bond is still blinking/spinning after making the change.
Although the instructions are clear, I’m somewhat reluctant to start doing things I really don’t understand. My entire reason for making the change is to stop the blinking/spinning bue light, and if the change does not do that, I won’t mess around with something I don’t understand.
So…
  1. Has anyone else tested and can confirm making this command line change stops the blue light blinking/spinning? Can you also confirm that after the change you can still use the app to adjust the intensity/brightness of what I presume is now a solid blue light?
  2. Any word from Bond on if / when they might add capability to the app to indicate the Bond should work offline?
