Customer reported:
I just installed a Minka-Aire Smart by Bond fan. It shows up as a bond device in HS4, but there are no controls.
I wonder, what’s the difference? It’s supposed to use the same protocol?
Customer reported:
I see you asked for a screenshot in that thread - hopefully you can get a screenshot of the Bond app screen in addition to HS screens.
(I know my SBB devices do not have a “remote template” like your user is used to seeing on the other devices they have on Bond Bridge)
Also could have the user try manually sending curl commands to get a listing of what Actions are there, to verify if the issue is the device, the Bond API, or the HS plugin getting confused by something.
Yeah, it was /v2/bridge/ command
Ah, okay. SBB doesn’t have that endpoint, and I see in that other forum you’ve updated the plugin to handle the difference.
