FYI, I’m planning to write Bond plugin for HomeSeer as soon as I get Bond devices for testing
Solved for this, turns out Homeseer lets you execute commands like curl natively and all you do is feed it the info needed just like we got it working via putty
thanks all for the help!!
Kudos @residualimages for the amazing support!
I started HomeSeer plugin (in BETA), see
Released
I also struggled with this. You’ll find 2 simple javascript / html approaches here: GitHub - evengers/bond2somfy
One uses nodejs as a proxy.
The syntax is probably what you are looking for but there are still stumbling blocks (CORS related)
