I have Select blinds. I have 3 blinds in my office. I have setup a schedule but I want to open only half way. How would I do that? When they close they do go all the way closed.
The only way to do this would be if there was a slider control available in the app. You can try to see if it can be enabled: https://olibra.zendesk.com/hc/en-us/articles/360060996252--Bond-Bridge-Pro-Shades-with-slider-control
Just got a reply from Bond. They are working on a slider for the app. I really don’t understand. I had set up everything last year when I purchased the shades and Bond. All worked perfectly. I had a major internet problem and had to redo my Bond settings. A hassle but did it. So when I had setup the first shade to open at 8 am it gave me an option to set position to 50% closed everyday. When I went to set the same for shade #2 there was no option. Shade #1 worked opening to 50%. Very strange.
Hey @67Corvette ,
I’m Endy, one of Olibra’s engineers.
I believe that shade #2 is missing some configuration to allow it to be handed to 50%.
Can you share with me your Bond ID so I can look into some general logs and try to assist you with that? You can send it via a DM if you prefer ![]()
Can you please help me as well. Installed select blinds rollers and need to setup that they only open half way.
Looks like your shade lower limit is set incorrectly.
I believe this video can help you with the instructions to update the shade limit:
THank you for the prompt response, I was looking for slider control so I can leave them open only half way using the app and also setup in a way that the zebra shades remain open. More of scheduling. Can you help?
