This iOS build adds support for so-called “state remotes”, which send a control signal containing the entire state of the device (speed, light value) rather than a simple command. These remotes typically have LCD screens.
In particular, the new ceiling fan remote FCC IDs which are fully-supported in this release are:
CHQ7096T
kujce10305
chq7096t
l3hfan9t
kujce10203
The app is currently under Apple review and will be available via Testflight in about 24 hours. Everyone with access to this post (and an iOS device that you have used with the BOND) should be on the Testflight list, and you will receive an email only once the Testflight build is approved by Apple and available to test.
Good question! The iOS app v1.109 (4) contains firmware v1.108.3, which does not have the experimental DHCP fix. So I’d recommend holding off until we roll the DHCP fix into the firmware in the apps. We haven’t gotten any negative feedback on the firmware v1.108.4 so it’s looking good for mid next week (plus/minus Apple approval).
OK I updated to both the Test Flight app and the firmware. I am unable to program BOND for my State Remote.
FAN-9T. FCC ID L3HFAN9T I could use some hints on getting this to work. The traditional hold down the button to program not helping.
Should be OK now. Try rapidly pressing the Light or Fan button while recording. (This remote only transmits once per button press, unlike most others that continue to transmit as long as you are holding the button down.)
OK no real luck. I started by testing with light. It took the command. I turned on the light using remote control. Pressed the test button on my phone it went off for a split second then back on. Same for all other options.
Ok, we narrowed down the issue to your remote transmitting a slightly shorter gap between packets, which is just under a threshold we use for separating the packets apart. Thus the lack of recognition.
