Fan speeds command will not work still for me
I have read through the posts. I have tried all the recommendations but still nothing. I have tried set and turn on with the device name an speed but I get the great apology. I also notice that in the google home app the fan light will turn on/off via the app but the fan is shown as off line and can’t be controlled there. Not sure if this has something to do with this.
I can turn the light on and the fan on as long as I don’t ask for a speed things work.
I have tried to set up a routine thinking I google doesn’t understand me but I was able to get it to work one time but so far not again. I even setup the same routines for my other two fans but nothing there.
I am moving my house from Alexa to google and this is one of the last sticking points.
Thanks for any further suggestions. I am on version 2 of software platform but still had an issue on version one. My bond is about 4 years old so not sure if this older hardware can be an issue.
Blockquote
The older hardware has some issues, but it’s mainly WiFi-related, nothing that’d result in Google Home not working differently than the new hardware.
Google handles the voice → intent mapping, and recently there was a change:
  • “Set to speed #” - Not working as of 11/29/19
  • “Set speed to #” - Working as of 11/29/19
Have you tried the second phrasing?
Yes I have tried both set and turn with no luck with either.
I accidently found that using the room name rather than the fan name works better with Google. EG I have a fan named “Fan Alpha” in room “Bedroom 1”.
“Set Bedroom 1 fan speed to 2” almost always works whereas “Set Fan Alpha speed to 2” invariably fails.
This of course would be problematic if a room has multiple fans. I have not had to deal with that yet - but probably will soon.
In this case, I’m really not sure what could be happening here. I recommend you contact customersupport@olibra.io if you haven’t already done so.
Also, @joaoricardo can maybe provide more insight.
Please let me know if you have found a solution since I have the same problem as well.
I’ve tried all of the following, and none seem to work:
“Set fan speed to (#/high/medium/low)”
“Set (Room) (fan name) speed to #”
“Set fan to (high/medium/low)”
“Turn fan on to speed (#/high/medium/low)”
“Set fan to speed (#/high/medium/low)”
All I get in response is “I don’t understand”. What DOES seem to work is the lights. I can set them to any brightness and turn them on and off without issue. Only the fan is the issue.
Anyone have any fixes?
