Hi guys,
I have used Bond Bridge for a while to control a Hayes “dumb” ceiling fan. This setup is Bond Bridge > Home Assistant > Apple Homekit.
In the Bond App I have the ceiling fan set to reverse and state tracking set to “On”. In Home Assistant I have it also set to reverse. Finally, in Apple Home App i have it set to reverse in all scenes.
I never use the fan remote to control any of the fans.
However, recently when changing scenes via Apple Home App, the fan direction seems to change. Let’s assume the following…
- Fan is stopped
- “Good Morning” scene is activated which sets fan speed to 6 and direction to reverse. Fan is observed to be running in reverse.
- “Good Evening” scene is activated which which sets fan speed to 4 and direction is set in Home App to reverse. As such, the fan should just continue spinning in the same direction it was, but reduce speed down to 4.
That isn’t the case. The fan direction is changed when the new scene is activated. However, Bond, HA, Apple Home show the fan direction as being in reverse when it is in fact now spinning forward.
What is strange is that I have two Bond Bridge’s in separate rooms which use the same scenes. The issue above is for the Desk Area Ceiling fan, but the Bedroom Ceiling Fan doesn’t have the same problem. However, I have come to think that this may be because the Bedroom Ceiling Fan speed is never changed to anything other than 6. It would appear to me that changing the speed of the fan between scenes is causing the direction toggle to be sent. If the fans are turned off, and then turned on via a scene (as opposed to running and a scene changing the speed) then the direction always “starts” correctly as reversed.
I can see in the Bond App logs that fan speed and direction are being set. On both fans, but only the Desk Area Ceiling fan is changing direction.
My remote has “Toggle” for fan direction. Both ceiling fans and remotes are exactly the same models. As stated before. I never use the remote to control the fans so there should not be any state confusion.
It is driving my crazy as I cannot work out why this is happening.
Is there a way to stop bond sending a direction signal at all? These fans seem to “recall” the last direction when the speed is set. If I can stop Apple Home > HA > Bond Bridge sending a fan direction command at all, then I would probably get the issue solved.
I have no need to ever have the fan spinning forward, it should always be in reverse (counter-clockwise).
Any ideas are much appreciated, thank you.
