I have been looking for a quick way to print/ save a list of all the devices and their info in order to give to an integrator. If there a way to do this currently?
I don’t believe there’s an easy way to output devices / properties / etc; I would say the easiest way is just cURL’ing into each of the device nodes and outputting “name”, “type”, and “location” (at least those, if not also the corresponding “commands”) - could even stream the output to a file so you had a .txt file at the end of those manual steps.
