Delay between calls
@jacob @merck I want to re-send the command in this case, but since I don’t know where the failure is - on sending or receiving side - so I don’t know if the Bridge received the command or not. Which is crucial in case of “toggle” command.
If you need to implement a retry mechanism in your integration, please contact the Bond Engineering Team via the Bond Forums
