Problem is - it doesn’t timeout from single command, but when I request all devices and groups, you can see that sometimes reply takes more than 2-5 sec, sometimes more than 10:
11/07/2023 0:00:45 AK Bond Info [1447] 'My Bridge': Execute(sync)'GET' {Response} [http://192.168.1.26/v2/groups]: The operation has timed out (tm 10018). Retry(2)
11/07/2023 0:00:45 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/groups): 10018 ms
11/07/2023 0:00:34 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/2e65abcb/state): 3423 ms
11/07/2023 0:00:31 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/332d1883168e91f6/state): 204 ms
11/07/2023 0:00:30 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/47cc0984/state): 161 ms
11/07/2023 0:00:29 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/79238147/state): 71 ms
11/07/2023 0:00:29 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/1756f1e7/state): 436 ms
11/07/2023 0:00:28 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/4a28142a/state): 254 ms
11/07/2023 0:00:27 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/332d1883168e91f6): 111 ms
11/07/2023 0:00:26 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/79238147): 57 ms
11/07/2023 0:00:26 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/4a28142a): 59 ms
11/07/2023 0:00:25 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/2e65abcb): 62 ms
11/07/2023 0:00:25 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/47cc0984): 71 ms
11/07/2023 0:00:24 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/1756f1e7): 107 ms
11/07/2023 0:00:23 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices): 94 ms
11/07/2023 0:00:23 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/bridge): 100 ms
10/07/2023 23:59:23 AK Bond Trace [1447] 'My Bridge': *** StartUpdateTimer: 60000 ms
10/07/2023 23:59:23 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/2e65abcb/state): 5416 ms
10/07/2023 23:59:17 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/332d1883168e91f6/state): 1888 ms
10/07/2023 23:59:14 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/47cc0984/state): 235 ms
10/07/2023 23:59:14 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/79238147/state): 1394 ms
10/07/2023 23:59:12 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/1756f1e7/state): 2875 ms
10/07/2023 23:59:08 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/4a28142a/state): 46 ms
10/07/2023 23:59:08 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/332d1883168e91f6): 57 ms
10/07/2023 23:59:07 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/79238147): 52 ms
10/07/2023 23:59:07 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/4a28142a): 54 ms
10/07/2023 23:59:06 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/2e65abcb): 66 ms
10/07/2023 23:59:05 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/47cc0984): 62 ms
10/07/2023 23:59:05 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices/1756f1e7): 61 ms
10/07/2023 23:59:04 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/devices): 62 ms
10/07/2023 23:59:04 AK Bond Trace [1447] 'My Bridge': Request Time(http://192.168.1.26/v2/bridge): 174 ms
10/07/2023 23:58:04 AK Bond Trace [1447] 'My Bridge': *** StartUpdateTimer: 60000 ms
And yes, I log the FW version, and it looks like it started after update “v3.13.6” (but not certain)
I also don’t know of any other reports of a slowdown in the API on recent FW releases.
I second @residualimages’s ask about the Bond Home app. If the app is also very slow on the same Bridge, that tells us something is wrong on the Bridge FW side. If the app runs normally, then it’s something on the HomeSeer side.
Actually, if you do a swipe to refresh on the My Devices screen, the app will re-request every endpoint on the Bridge. This may take several seconds as it needs to read every device, group, device state, property, command, etc.
Crucially, the app uses parallelism of only 2 or 3 workers per Bond. That is, there’s only 2 or 3 outstanding HTTP connection attempts to the Bridge at any time. Just using a single request without any parallelism achieves nearly the same performance actually.
You may run into problems if you use a high parallelism, where there can be many outstanding HTTP requests. The TCP/IP stack on the Bridge only keeps track of a limited number of connections attempts (I think up to 8), and only one is handled at a time. So, if you are sending more than 8 requests at once, your source TCP/IP stack is going to go into exponential backoff which can result in long waits and timeouts.
I’m not certain that this is the problem here, just coming up with a hypothesis.
