BOND Local API BETA Sign-Up
Is it connected to wifi? I had to do a “Green reset” my pushing the reset button for 5 seconds until the circle turned green then reconfigured the wifi. Check here for directions.
Ditto here.
Was able to use the BOND app to reconnect to home WiFi after doing a ‘green reset’, and putting Android device in airplane mode + manually connecting to BOND setup WiFi.
The first time, the BOND lost connection with the app while I was typing in the SSID password.
BOND device rebooted itself. Force closed the Android app, then opened it again and hit the + sign once more.
This time, it took the WiFi credentials without issue.
Mine is flashing green, but it won’t come up with the setup screen.
Do you see “Bond Setup AJ14749” in your list of available WiFi networks? I ended up going into airplane mode, toggling WiFi back on, manually connecting to that BOND WiFi network, and then hitting the + sign in the BOND app.
Yes it is there, and I connected to it. Then it goes to where I select my network and I select it if it shows, enter password and it fails to connect. Or I get a network time out error. Tried airplane mode toggle and now my BOND will not find the network.
That’s annoying.
There is always the manual API connection way, if you connect your computer to the BOND setup network to get all those details.
From Chris - here’s a video showing how to set up the BOND on WiFi using only the Local API: https://drive.google.com/file/d/1St_PZIqqnkbjNtjUFw-6sLiV_IzFBN3y/view?usp=sharing
OK finally got to the install screen Now have to set up all devices again.
OK this is screwy I went to setup a fan, pressed add then add device and choose the light it went to the start screen I pressed start and it jumped to the same screen again and said couldn’t find remote.
Oh man. Sorry to hear that.
When mine got upgraded, I did not have to re-add my devices for some reason.
I have only tried adding devices via the API so far after that (since I do not have any other “real” devices installed at the moment to set up with new remotes), and that has worked.
If you still have issues by tomorrow, I will remove one of my real devices and try re-adding it to see what my experience is like.
I have removed all my devices and tried from scratch, jumps back to start, this bricked the BOND. Hopefully BETA team will help. As soon as I press start I get Hmm BOND did not discover your remote.
I’m also trying the beta firmware. I have 3 fans in the house all controlled by individual remotes. For some reason now I can only get one device to setup properly. This wasn’t an issue on the other firmware.
Having signed up for beta firmware (2.5.0) to try to work on the API, I downloaded the beta app and upgraded the firmware - ended in blue flash of death. Tried reset multiple times, can consistently get it to green flash, but once configured, goes into blue flash again. I downgraded it to 1.138.1 and it works again (except for some reason 3 of 4 devices are gone - strange that not all are gone) Tried upgrading to 2.5.0 again, same thing. Giving up for now. :frowning:
Hi Michael and Joel — sorry you’ve had trouble with the experimental firmware. — Indeed we have a bit more work to do before it’s production ready!
Joel: If you’d like to try the Local API, you can also try the BOND with serial number starting in Z. That has production-ready V2 firmware already installed. We just shipped v2.5.2 yesterday that fixes a few minor issues.
Michael: The 1 device that remains is because it is stored on the Cloud. Those devices are not currently available via the Local API. I know this is not evident from the current UI, and we are planning on straightening that out.
Any idea why I can only add one rf fan even using the beta firmware?
I installed firmware on the Z BOND and will test later. What about the other two units that will not take any devices? Are There better instructions for the local API for those? The video is hard to use.
UPDATE: Z BOND Will not find State Remote. Also, regular remote also doesn’t work. It is haphazard. It finds the function flashes green then when testing BOND flashes but functions don’t work.
All three BONDS now no longer function including the Z BOND.
Written documentation and some limited tutorial is here: http://docs-local.appbond.com/#section/Getting-Started
The video was meant to give some pointers to residualimages. We could do some more videos more carefully…
@joel What format do you think is most useful? Videos or text tutorials for the API? Or perhaps a mix of both?
Sorry if you wanted to keep your not-100%-polished video more secret haha!
Text is better to follow along with. I would like to get my system up again as all three BONDS no longer work.
@joel You can follow the instructions here to downgrade: Local API BETA -- How to Set Up
Not sure why the Zermatt (ZZ) BOND is not seeing your state remote. That would be a separate issue… but let us know the FCC ID.
