Using remote with FCC ID:. CHQ7225T, and using the StartDecreasingBrightness command, I receive a HTTP of 400 Bad request.
HTTP/1.1 400 Bad Request
Content-Length: 54
StartDecreasingBrightness is a valid command, as noted by the response:
HTTP/1.1 200 OK
Content-Length: 528
{"":“d96da0d0”,“OEMRandom”:{" ":“c33ce16c”},“TurnOff”:{"":“2ab10e78”},“SetSpeed”:{" ":“f7dc2578”},“SetDirection”:{"":“80b91073”},“OEMTimer”:{" ":“3a3f43e6”},“StartDecreasingBrightness”:{"":“860147be”},“StartIncreasingBrightness”:{" ":“0dc5e82f”},“ToggleLight”:{"":“3c0b2188”},“Stop”:{" ":“aac378bd”},“TogglePower”:{"":“e7bdb8c8”},“TurnOn”:{" ":“1af79a43”},“IncreaseSpeed”:{"":“a66973cb”},“DecreaseSpeed”:{" ":“795be9e6”},“ToggleDirection”:{"":“bbc186d7”},“TurnLightOn”:{" ":“80d1778d”},“TurnLightOff”:{"_":“d7ce86c5”}}
merck
August 9, 2021, 7:20pm
2
Please check the body of the 400 reply, it should contain an error code plus a human-readable error message that expands on the “Bad Request”.
It states that an action that is retrieved using the actions query is not supported.
here is the available actions:
but when sending the command “StartDecreasingBrightness”, I recieve the error:
Content-Length: 54
{"_error_id":61,"_error_msg":“action not supported”}
merck
August 10, 2021, 12:32pm
4
I assume you’re doing this:
PUT devices/{}/actions/StartIncreasingBrightness {}
You could instead try:
PUT devices/{}/commands/{cmd_id}/tx {}
Where cmd_id is the ID of the command that has action: StartIncreasingBrightness.
I was following the syntax of the documentation found at: Bond Local API (appbond.com)
My command was:
curl -H “BOND-Token: 5d8eXXXXXXXXc570” -i http://192.168.1.47/v2/devices/3cf71c81/actions/StartDecreasingBrightness -X PUT -d “{“argument”: 3}”
here is what I am trying after reading your suggestion:
curl -H “BOND-Token: 5d8eXXXXXX4dc570” -i http://192.168.1.47/v2/devices/3cf71c81/commands/1bb3664a/tx -X PUT -d “{“argument”: 3}”
this gives a message:
HTTP/1.1 405 Method Not Allowed
Content-Length: 52
{"_error_id":56,"_error_msg":“method not allowed”}
If I intentionally change the numeric value for the command to something random, the message changes to:
HTTP/1.1 404 Not Found
Content-Length: 0
this tells me that the syntax may be correct, but the actual value has no matching command, hence the 404 error.
For clarification, my understanding is that if I use the commands option, that I can get the numeric values. If the commands and the actions follow the same order relationship, I should be able to correlate the numeric value for the action value.
merck
August 10, 2021, 4:59pm
6
Try removing the argument.
curl -H "BOND-Token: 5d8eXXXXXXXXc570" -i http://192.168.1.47/v2/devices/3cf71c81/actions/StartDecreasingBrightness -X PUT -d "{}"
SUCCESS! I tested your syntax from above, and got the expected result!
Thank you for your patience.
merck
August 10, 2021, 7:22pm
8
Ok. — Our error message there is wrong. It should say “action does not accept an argument” or something like that rather than “action not supported”
This syntax worked for me to control my somfy awning. The api documentation is good but a little unclear
merck
August 8, 2022, 9:28pm
10
Glad it was helpful. If there’s something specific you’d like to re-word I invite you to open a PR GitHub - bondhome/api-v2: Bond V2 API Documentation
