I’ve been using the info from http://docs-local.appbond.com/ to try to create a Windows application. I will be glad to provide you the application and source once I have completed it if you would like to distribute it
But I’m running into some issues. First when I attempt to issue an action that is returned from querying the device, so of them return a 400 invalid request. Then when I use a sniff to see what the Android app is doing rather than issuing the TurnOn / TurnOff action, is issues at commands//tx, and to be more confusing the hex number is not listed in the command listing, and is different for different devices. How should I be trying to issue these commands?
Also, I’d like to make this like the android app, where the first time you run it you give it your logon credentials and it retrieves the information on your bridge. Can you help me with how to do that?
