# Valor G4 Gas Insert
**URL:** https://forum.bondhome.io/t/valor-g4-gas-insert/2065
**Category:** Fireplaces
**Created:** [November 30, 2020, 7:57pm UTC](https://forum.bondhome.io/t/valor-g4-gas-insert/2065 "2020-11-30T19:57:54Z")
**Posts on this page:** 1
**Showing post:** 3
### Author: ![residualimages](https://sea1.discourse-cdn.com/flex019/user_avatar/forum.bondhome.io/residualimages/32/74_2.png) [@residualimages](https://forum.bondhome.io/u/residualimages)
#### Post date: [January 14, 2021, 11:54am UTC](https://forum.bondhome.io/t/valor-g4-gas-insert/2065/3 "2021-01-14T11:54:25Z")
If the double tap is just a repeat of the command sent with a single button press, you could learn the single button press, then [adjust the repeat count](https://forum.bondhome.io/t/need-to-hold-repeat-rf-signal-for-a-few-seconds/1059/2) by using the API.
_[View the full topic](https://forum.bondhome.io/t/valor-g4-gas-insert/2065)._
