# Unable to access command/signals field (204 resp)
**URL:** <https://forum.bondhome.io/t/unable-to-access-command-signals-field-204-resp/5216>\
**Category:** Smart by Bond\
**Created:** [January 18, 2025, 1:19am UTC](https://forum.bondhome.io/t/unable-to-access-command-signals-field-204-resp/5216 "2025-01-18T01:19:50Z")\
**Author:** ![residualimages](https://sea1.discourse-cdn.com/flex019/user_avatar/forum.bondhome.io/residualimages/32/74_2.png) [@residualimages](https://forum.bondhome.io/u/residualimages)\
**Post date:** [January 18, 2025, 3:14am UTC](https://forum.bondhome.io/t/unable-to-access-command-signals-field-204-resp/5216/2 "2025-01-18T03:14:49Z")
@merck - is it still the case that (some) [Templated devices do not expose their signal endpoint / data](https://forum.bondhome.io/t/need-to-hold-repeat-rf-signal-for-a-few-seconds/1059/50)?
Is there an API way to modify reps even when this is the case for a device?
Also, @bsettlemyer , nice digging so far. Welcome to the forums.
Do you by chance know which Template you have based on the information in Bond, and what brand you see on your blinds?
_[View the full topic](https://forum.bondhome.io/t/unable-to-access-command-signals-field-204-resp/5216)._
