# Star fans - control dimmer lights, and real-time status indication
**URL:** <https://forum.bondhome.io/t/star-fans-control-dimmer-lights-and-real-time-status-indication/1922>\
**Category:** Fans\
**Created:** [October 17, 2020, 6:43pm UTC](https://forum.bondhome.io/t/star-fans-control-dimmer-lights-and-real-time-status-indication/1922 "2020-10-17T18:43:14Z")\
**Author:** ![residualimages](https://sea1.discourse-cdn.com/flex019/user_avatar/forum.bondhome.io/residualimages/32/74_2.png) [@residualimages](https://forum.bondhome.io/u/residualimages)\
**Post date:** [October 18, 2020, 1:10pm UTC](https://forum.bondhome.io/t/star-fans-control-dimmer-lights-and-real-time-status-indication/1922/2 "2020-10-18T13:10:19Z")
When with the original remote, you hold a button to dim, the Bond team [has explained](https://forum.bondhome.io/t/setbrightness-isn-t-working-and-turnlighton-act-as-toggling/1767/4) that it’s difficult to have an effective dimming strategy outside of the app. If the original remote doesn’t have a “brightness percentage” indicator or discrete commands to say, “set brightness to 30%” directly, a Bond bridge won’t be able to magically add that ability to the fan’s receiver, nor turn that fan’s receiver into a real-time state transceiver.
I don’t see the RF range this fan series uses in the documentation, but I do see it [listed on Amazon](https://www.amazon.com/dp/B07DGQ5VMG/) as compatible with Bond, so someone _should have tried it_ before marking it as such.
If you got a Bond Bridge and only controlled the fan (power and speed) and light (power and start/stop dimming) through the Bond app and integrations using Bond, there is a “trust state” feature you can use to have Bond track whether or not it turned on/off fan, or turned on/off light (said another way, using the Bond Bridge sometimes and the original remote other times will make any integration unreliable as to power and speed state); however, as explained above, the Bond Bridge will not know anything about current _brightness_ level, due to sort of a weak point of the majority of RF based fan kits from manufacturers. Doesn’t mean you can’t attempt something utilizing X seconds of “send dim” commands through Bond controls within SmartHome programming, but I feel like most forum members with these kind of limited fans (myself included) cannot achieve reasonably reliable brightness settings.
_[View the full topic](https://forum.bondhome.io/t/star-fans-control-dimmer-lights-and-real-time-status-indication/1922)._
