So a little over a year ago I used to have my pergola working just fine in momentary mode and I was able to configure it with a slider and calibrate the open and closed time. My luxury pergola uses the Gama electronics template RMS148 remote and if currently setup and keeping the system in momentary mode the louvers will budge in a small increment when opening or closing and i am unable to enable the option to have a slider and calibrate the open and close time which would usually just loop the signal and work just fine. I saw a post about other gama devices having a change and not supporting momentary mode anymore? Is there anyway I can configure it to work again. Whenever i restore my device that used to work I would get an error about bonscript something(its been a while and i dont remember off the top of my head) and now it just doesn’t do anything. I would appreciate any insight. I think before when I set it up i picked a pergola option that had the slider and then i changed/relearned the buttons for open and close but that seems like its no longer possible as the only options are to reset the buttons to template and not relearn anymore?
