FCC ID of KUJCE9OO1 is it supported
I have the FCC ID of KUJCE9OO1 is it supported
299.6 MHz signal - technically the newer revision (serial numbers start with ZZ) of the Bond Bridge has the hardware to support it.
The older, 1st generation Bond Bridges (starting with serial number of A or B) technically only supported ranges as low as 300 MHz.
So… Yes, most likely. But only the newer Bond Bridges with serial number starting with ZZ.
It worked!!! Way better than matterlink
