# Adding custom buttons
**URL:** <https://forum.bondhome.io/t/adding-custom-buttons/1230>\
**Category:** BOND Setup and Hardware\
**Created:** [January 18, 2020, 3:09pm UTC](https://forum.bondhome.io/t/adding-custom-buttons/1230 "2020-01-18T15:09:45Z")\
**Showing post:** 11
**Author:** ![residualimages](https://sea1.discourse-cdn.com/flex019/user_avatar/forum.bondhome.io/residualimages/32/74_2.png) [@residualimages](https://forum.bondhome.io/u/residualimages)\
**Post date:** [May 12, 2020, 9:12pm UTC](https://forum.bondhome.io/t/adding-custom-buttons/1230/11 "2020-05-12T21:12:05Z")
They’re really all interconnected.
I did have better luck adapting a Fireplace or Fan device (turning off database lookup and recording each button press manually) vs using the Generic Device (which seemed more limited).
Counter-intuitive, I know.
But then I could rename the buttons. Sadly, I have not been able to find a way to change the _icon_, but at least the label. You’ll find my notes in that post I linked above. 🙂
For instance, I have an upright floor lamp which is a Fireplace as far as BOND is concerned, because I needed more than the 3 buttons the Generic Device gives.
I used Flame Up for increase brightness, Flame Down for decrease brightness, Low Flame as a ‘change LED color/temp’, and Toggle Light for power toggle.
_[View the full topic](https://forum.bondhome.io/t/adding-custom-buttons/1230)._
